The temperature would slowly creep up whenever it wanted to, and every third day had to be topped off with coolant. A turbo hose on the passenger side was leaking and would only squirt water under boost. Nonetheless the gurgling could be due to either a bad hg or air in your system. The compression test was around 140 on all cylinders but the hg was bad when the heads were pulled.
